Yanmar injection pump problems
   / Yanmar injection pump problems #1
ohiogar
John Deere 4300
Hello from Ohio,
Bought a 955 JD Tractor that would not start.
Yanmar 33hp motor Yanmar 51360 injection pump
Forgive me if i do not know the correct part names but
No fuel was getting past the IP. After new battery and working the
starter a few times the fuel shutoff started working on it's own.
removed the injector lines, bone dry,
Removed the side plate and 2 of the "tappets" were not moving at all.
Took the valve bodies off of the top. all looked clean but #1 cylinder
was the only one that cycled with the key switch.
sprayed it all good with pb blaster and tapped the center plungers
gently with a brass punch 2 freed up and center one was stuck. There is a large
hole in the side of one of the plunger housings. I was able to insert a dental
tool in the center assembly and tap gently bringing that housing up and out
of the pump. Used a 22cal bore brush to clean the dark film. Now all of that works freely.
Put the valve assembly's back on the pump. all works freely but no fuel up top..
NOW fuel oil fastly trickles down through into the lower tappet housing. I do not think
it is supposed to flood that lower housing. In a parts breakdown I did not see any
seals separating the fuel chamber from the tappet chamber.
What am I overlooking or not doing here.
Thannks in advance, Gary in Ohio
   / Yanmar injection pump problems #2
U r correct, no fuel to the lower half..
When u took the top apart the “barrel” came off its locating pin and when u tightened it down, u sheared it..
It’s a good thing it didn’t start or you’d have parts scattered everywhere.. lol
I can fix it for u.. but u have to stop RIGHT NOW..
U can contact me directly at:
My screen name at aoldotcom
Godwin CD100S Dri-Prime S/A Towable Dewatering Pump (A44571)
Godwin CD100S...
2013 Chevrolet Impala Sedan (A44572)
2013 Chevrolet...
2025 Wolverine SBM-12-72W Sickle Mower Attachment (A47484)
2025 Wolverine...
Water Buffalo Roller (A47484)
Water Buffalo...
2019 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A44571)
2019 International...
2025 Wolverine LHR-PC90H HD Plate Compactor (A47484)
2025 Wolverine...
