California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,634
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
It worked for me! US YM240 is preferable because you aren't shut out of US parts. Otherwise identical to YM2000.
353 hours doesn't mean anything. 3-digit hourmeter is just an oil change reminder. 1300 hours if you don't see much wear on pedals or other evidence of high hours. At near 40 years old the individual condition is what you need to appraise. 2300 hours is more likely, comparable to 80k miles on a modern car. Used, far from worn out.
You mentioned you have worked around diesel trucks so you likely have some instinct for excessive or wrong-color smoke, or hard starting. Just do a careful appraisal. $2400 is little enough that you can get out of it at what you paid, or more if you clean it up. Be sure all the gears work properly including hi/lo range. Brakes and electric are cheap if needed. Rear tires expensive. Check for bubbles in the radiator. (head gasket or head, repairable). Budget a few hundred $ for the unexpected such as no headlights or radiator needs rodding out, clean it up, enjoy it!
For myself I wouldn't be afraid to buy a $2400 Yanmar if no evident faults. Up to you whether it matches your application. I hope it looks a little less thrashed than mine.
