yanmar tiller oil question
   / yanmar tiller oil question #1
wendelin
Bronze Member
Oakley KS
JD 185
I changed oil in the gear box tonight. One quick question.
When filling, just fill untill oil starts to come out of the plug in the back of the gear box?
Should I drain the oil that the chain runs in?
What type of service maintance should I give the tiller?
I grease it alot and though about changing the oil every other year.
thanks for all your help
wendelin
   / yanmar tiller oil question #2
I bought my Yanmar tiller last year, Changed oil in both cases. The oil in the chain case was much dirtier than the oil in the gear case. So if it hasn't been changed in a while I would definitely change it.
   / yanmar tiller oil question #3
I second the oil change in the chain case. Several of the ones I changed had water in that oil. One time it froze and locked up the tiller. I usually fill it with diesel and spin it then drain and replace with 90 wt.
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
LOT NUMBER 251 (A53084)
LOT NUMBER 251...
