Yanmars advertised in California
   / Yanmars advertised in California #11
And sometimes there are still pretty good bargains. This morning, a clean little 1401D with box scraper (no loader) was listed for $1500. The listing is now gone, hours later. I'm sure he was bombarded with calls to pull the listing so quickly. Somebody bought a nice little tractor for a good price.
   / Yanmars advertised in California #12
I know, you kind of inspired me. I just finished putting a backhoe on my tiny Kubota B6000. I tested it out this afternoon. I want an excavator now, but it sure beats the daylights out of a shovel!
There have been several excavators around for what seem like reasonable prices, though far outside my "spur of the moment" budget. I just can't justify one. I need to buy a different property so that I can justify buying an excavator. :D A skid steer is about the same way for me. I can't think of a reason I would need one, so am not sure why I would buy it. I must be getting old... :laughing:
To be honest I probably didn't need a skid steer either for our 4 acres but I thought about it and some day when I get my own place I will be thanking myself I bought it. :thumbsup: The skid steer does make working on the property a lot more fun and it is way more productive than the Yanmar in terms of moving logs and burn piles. :thumbsup:
   / Yanmars advertised in California #13
Wow, that is a good deal. The place I got my skid steer from has a John Deere 4310 for sale with FEL for $8900 that "needs some love". Not a bad deal on a 30 hp Deere. :thumbsup:
   / Yanmars advertised in California #14
The skid steer... is way more productive than the Yanmar in terms of moving logs and burn piles.
Definitely true. The speed they do back and forth, tight loader work is astonishing, especially when comparing a standard shift tractor. Comparing machines of the same dimensions makes the difference even larger. Any of the dedicated machines are like that: excavators embarrass a backhoe of the same size, and nothing digs a water line faster than a pure trencher. A tractor is just so versatile, and is able to do anything adequately. Specialist machines do their "thing" better than all other options.
   / Yanmars advertised in California #15
Very true. The one thing I miss the most is having a 3 point hitch with a PTO. I kept the imatch off my Yanmar along with the telescopic lower links which will be put on my next tractor I buy in the future. My plan is to get a blank skid steer Plate and weld 3 tabs onto it and mount the imatch to is. I wont stop there, I also will use my 34 hp of auxiliary hydraulics to power a hydraulic gear box which would give me a PTO shaft. It will take some math to get it as close to 540 RPM as possible but it will allow me to run a 5' bush hog on the skid steer vs/ spending over $4k for a hydraulic bush hog. Plus i will be able to use a couple of the tractor implements I have left from when I had the Yanmar, a landscape rake and a middle buster. Both will be used in cleaning all of the debris from the woods and putting the debris in burn piles. :thumbsup:
   / Yanmars advertised in California #16
So i guess you will be using this thing for paid jobs, otherwise it really seems like a pointless trade? A farm tractor for your uses seemed way more valuable, granted there are things that both can do the others cant.:D
   / Yanmars advertised in California #17
I will probably get a few jobs with it so it can "pay for itself". You can see in the pictures I have attached what kind of stuff I will be using the skid steer for. The property I am working with is not very level, between tree stumps, piles of dirt, and areas where the land has been pushed clear with a small dozer a few years ago. What I love about the skid steer is how it can maneuver in the woods between trees, how much lift capacity it has, and how high it will lift. For my current needs, it suits the bill just right. :thumbsup: Lets not forget how much fun skid steers are to operate too. ;)
   / Yanmars advertised in California #18
I saw this advertised last night, and thought of this thread. I have redacted the phone number, but otherwise this is exactly as it appeared:
"yanmar tractor - $1500 (rancho cucamonga)
its a yanmar 22hp diesel cat 0. it stopped running i think its a fuel problem if you are interested text me at XXX-XXX-XXXX or call me at XXX-XXX-XXXX"
It says YM177 on the insignia. The tractor has sold, I found out this afternoon. Shall we start a pool as to when the new owner appears, looking for for a head gasket or injector pump? I recognize the possibility it is merely out of fuel, and needs a bleeding, or new filter, but I would not want to be the guy making that wager on such a rare unit as this. It's a nice looking tractor though. The paint is faded, but doesn't show any sign of rust, and the tires seem in reasonable condition.
   / Yanmars advertised in California #19
These are not Yanmars, but I found them interesting. The Honda seems like the ultimate yard tractor: Front and rear lifts with 551 lb capacity, front, rear, and mid PTOs, 4 wheel drive and steering, differential lock, etc. This one seems to be complete and have a multitude of attachments. I have no use for it, but it's a good price for that assortment.
The Super C is unique. I've not seen anything like that of such an old vintage. I assume it is an old vineyard tractor.
Honda RT5000 Tractor, 4 wheel drive, 4 wheel steer, lift hydraulics front and rear, (3) PTO attachment points ( front, rear, and belly). Dozer blade front, Gannon 3in1 grader rear, Weed mower attachment 36", rototiller attachment, Disc attachment, Dumping trailer, 4 extra tires and rims, roll/ sunshade bar. runs excellent. cost over $10,000 new $2500 NO LOW BALLERS. Delivery available XXX-XXX-XXXX
5I65Kb5Ff3M53N53Hbc5pe938c354834c1438.jpg5N55Ka5F53G73Lc3N8c5p7485cfcaae4c1851.jpg5Ic5Ne5F53L33I53o1c5p40be9c0910ab119f.jpg5N55W35M93I43Le3N4c5p337c889f73721b1f.jpg
5Ff5H15J23ke3Fa3Jec5p2ded207f9c261fd8.jpg5Nc5I65M53F93Lc3H1c5pc6c0bc016e041b2f.jpg5Nd5L15Gb3Kd3M23J4c5p4ba3a15e35b71795.jpg
1952 farmall Super C on stiltz running tractor and rare.
   / Yanmars advertised in California #20
I have not seen more than a few that old on stiltz but around here we see those tractors all the time it seems.
Also if that honda runs that is a good deal!
2017 Nissan Altima 4 door (A56436)
2017 Nissan Altima...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
Rhino DB150 (A57148)
