Yard Hydrants
   / Yard Hydrants #31
Kent, it came from HERE:
<font color="blue"> save your money and just install galv pipe coming up with a faucet on the end: it will freeze, but it will not burst, unless you try to cover it up to protect it: do this on the ones your definetly not going to use when the temp is below freezing, and save youself a lot of money and future work...repairing messed up yard hydrants...been there.. heehaw </font>
   / Yard Hydrants #32
Here's a link to a yard hydrant that has a self contained drain chamber. should eliminate any concerns about adequate drainage, i.e. in clay soil or high water table.
   / Yard Hydrants #33
   / Yard Hydrants
I want to be able to use them all winter.
   / Yard Hydrants
   / Yard Hydrants #36
</font><font color="blue" class="small">( Kent, it came from HERE:
)</font>
Heehaw is from Arkansas, not me -- that scattergun you're using is dangerous....
   / Yard Hydrants #37
)</font>
   / Yard Hydrants #38
i have seen galv pipe sticking up 2-3 ft with a faucet on the top, all the way up in Pa; and yes they do freeze, but no, they do not split or break, unless you put a shutoff valve in line and shut it off, or try to cover it up: as long as they are left out, they will freeze from the top down, and push the water back down the line, you try to cover it up or put a shut off valve in and it will freeze at the ground first and then come up the pipe and split the pipe: or freeze and have no way to push the water back down the line(shut off valve) and it will burst..
heehaw
   / Yard Hydrants #39
heehaw
   / Yard Hydrants #40
the faucets i put in are not usable in really cold weather of course: but where folks are getting broken pipes with this method, is when they "shut the water off to the faucet", which means putting a shutoff valve in line, so the water can't be "pushed" back down the line when it freezes: i have seen a couple folks stick a 5gal bucket over the pipe, and of course, it doesn't sit on the ground well enough to keep the cold air out, so the pipe freezes at the ground, and then the pipe burst. 20 years ago, i put in 4 yard hydrants: the one i use the most was replaced twice, so the third time, about 5 years ago, i changed it to this method: since then 2 of the others have rusted shut and broke when i tried to use them, so i am changing them too: the 4th still seems to work fairly well.
heehaw
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
2006 Nissan Xterra SUV (A55853)
2006 Nissan Xterra...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
