Yard Man 20HP Garden tractor
   / Yard Man 20HP Garden tractor #11
Well, perhaps the MTD's are made better over there, but they not known for being a long lasting tractor over here...
I hope it works out for you, it sounds like you are really limited in your choices over there...
SR
Will see what time will bring.
This was only garden tractor for sale on ads. Rest we lawn tractors, from 11...20ho, most of them with single cylinder, some of them with Tecumseh engine, with prices range from 800...2500$ USED!!!
Choice here is pretty narrow. It's possible to find JD:
Traktor-kosilica John Deere L120 automatic
or Kubota mower :
KOSILICA KUBOTA G -18 DIZEL too,
but for 3...6 times price (3 to 6000$)... I'd like to have Kubota diesel, but...that's out of my price range.
For price in $, divide asked amount by 6.5.
   / Yard Man 20HP Garden tractor #13
or Kubota mower :
That's what a kabota goes around here for me too. If this mower is a steal for your area get it and fix it. I own a few mtd tractors. From cheap ones to craftsman. All good so far. But Have bad ones. If you can fix it your good.
With electric clutch for deck you always have to have a good battery and they are slow to fully stop. Never has one that squealed
I decide to go into that adventure.
There's no New Yard Mans any more. They are replaced with Cub Cadets.
Same class CC costs 4 times more new.. OK, all new are hydrostatic. It's more comfortable and safe, but This one is cheaper to maintain and repair.
I plan to spend up to 200$, and it will be like new.
If it has some major issue, I'll resell it.
Does anyone have.User / Owner manual and spare parts list to share it with me?
Thx :)
Yard Man 20HP Garden tractor - overhauling
I was looking for other mowers too, but that one was unique. It is bigger and heavier built then other on ads.
Maybe little overpaid, but still...for that money I can buy 5...7y old small MTD!
I borowed van and broght it home. As owner didn't have 2 boards, it was tricky to load it into the van. Before that, i removed mowing deck.
As it will be my son's tractor, I parked it, between bigger brothers:
My 8y son tested it...
...and was very happy. His happiness is worth more then any money.
Problems about tractor:
- hood ears are broken by vibrations and age:
It will be repaired with small steel bezel (frame) soon. Need to make a drawing to laser cut it.
- drive variator belt is worn, and need to be replaced soon. Variator need adjustment for now.
- some squeaking sound on drive system. Probably some bearing is dry on idler pulleys.
- brake is non functional at all
- steering system has some "air"
- frame little rusty here and there
But engine is runing pretty fine. My concerns were little pesimistic.
Mowing deck. As I mentioned before, it was removed before loading, and then was a moment to see "what kind of cat in bag I bought".
First what was visible, was that right lifting ear was broken and welded wrong:
It needs to be cut down, aligned and rewelded. Not a big deal.
I saw that was necessary to do modification on hanging points, that pin will go though into another hole, to avoid unexpected uncoupling (which happens in past).
Deck looks never washed out in it's life. There are lot of dirt on it, especially from inside, slightly rusty from outside, on some spots.
All in all, I expected worse.
After dirt scraping with wooden spade, I untightened nuts with air impact spanner, and removed blades., then applied WD40 to all bolts which need to be removed
As you can see on the hub, there's grease zerk, which was never used :(
...and started to disassembly it. First were taken off pulley protections, and belts:
Then hubs, idler, protection parts, casters...
...and deck was empty:
It was visible that it needs rust removal, evenatually rust holes patching, and new properly rust protection.
Knives are worn, but can still be usable, but wings are totally worn. They need to be replaced soon.
But, all of that was expected, and was not a problem. Biggest concern were blade shafts: on all three shafts/spindles, splines are worn out, so blades are rotating freely on it!
Some idiot didn't set it properly before nut tightening!
Shafts/spindles need to be replaced. Each one costs abour 30$, and this really pissed me of!!!
Then I untightened top nuts, and removed pulleys, and pull spindles out. I found grass in the bottom bearing, protections fell of, bearings were dry...
After all suprises, I need a bed...
Two of them went easy, but...
On third one, pulley went out with hammer and woden piece, but shaft won't. I try to "convince it" with 5lbs hammer, heat inner bearing ring with gas burner, cut it with an angle grinder...but it didn't give up! I broke ball cage, that I can group a balls:
From piece of 1/8" thick steel plate I made a kind of puller, with T-shanks from two M6 (1/4") 8.8 grade bolts:
and tried to pull it out. Puller bolt was M16 10.9 grade bolt, with ball on it's end. One shank broke, but bearing didn't move, even a litle.
So, if the rough force don't act, it was not properly applied :D
Now was a time to use drastic measures.
I made another puller from piece of 3/4" pipe, with welded M16 nut on the top of it.
Anther side of the pipe I MAG welded for inner ring:
On this photo it was set back after it was removed, just for example, as it will not be visible on place.
Bad thing: Nor this attempt was sucessful again, as the ring broke near the welding!
But good thing happened: weld broke off bigger piece of iner ring...
...that I could take out balls, one by one, and disassembly bearing into two parts,
pull the sahft assembly out, and release the hub:
But ring still didn't give up! I need to cut it with angle grinder and hit with hammer to broke, and then pull it out from the shaft.
Worst job (up to then) was done!
When I cought a time, I continued with deck works.
Wrong welded ear was cut off. As you could see on previous pics, holes were pretty worn out, and that was a chance to repair them.
Holes were filled/closed by MAG weld, and drilled again. Fortunatelly, there was pilot hole, so I could align ear properly and weld it on.
I noticed that left ear bracket (where is teeth wheel for deck leveling) was misaligned set in the factory, so I cut it off, align it by pilot holes and properly welded.
Deck was pressure washed and dried with compressed air, so rust inside was nicely visible.
Thank Godness, there weren't any holes or too deep "valleys", so it was not necessary to patch it.
All in all, deck was in pretty good shape, according to it's age (14y) and (lack of) maintenance. Maybe even better: dry deposits protected it.
Deck was powder painted, but paint had bubbles and fell off on some spots. On places where paint was OK, wire brush on angle grinder couldn't rip it off. BTW, wire brush on angle grinder couldn't remove rust from inside the deck (as it was not smooth).
So, it was decided to do the job on best posiible way.
First, and most expensive, step was this:
Professional sand blasting. It cost me about 35$, but it was worth every penny
Just for ones who don't know: compressor for sand blasting was driven by 75hp Deutz 4-cylinder engine :D
At the end of the day it was looking nice:
A few days later, deck changed a colour slightly outside...
and inside:
and it was brought to the factory for make best possible protection: hot zinc coating
It loos pretty from outside...
... and even better from inside:
Zinc coated were and other exposed parts:
But, that was just a first step. Few steps will follow later.
Deck was, after zinc coating, painted with 2-component reactive primer:
Primer is sprayed at high pressure.
so, I think that it will be good protected from inside too:
Now I need to assembly inside protections, and do a final painting.
I tought that good protection will be with car under body protection (I don't know proper name), and pain it over. What do you thinka about that idea?
As I don't have dark green or yellow paint at disposal, deck will be painted either in light grey (ivory) or in red colour (I didn't decide yet).
I know only that spindle pulleys will be red :)
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
