Yard size of 723 bucket?
   / Yard size of 723 bucket? #1
rk246
Newberg, Oregon
Kubota 3830 HST
I was wondering if anyone could tell me how much the 723 bucket will hold? I was figuring about 1/3 of a yard? I didn't try to measure and do the calculations because I am not very good at math, strong back, weak mind... I looked through all my literature but could not find it?
thanks,
Ryan
   / Yard size of 723 bucket? #2
10.8 cu. ft. 27 cu ft equals 1 yd. heaped full it might hold 1/2 yd.
Ron,
So I was unloading gravel last night out of the trailer, (wouldn't dump, dead battery) and I wasn't really heaping it mostly kind of flat, so probably just under 1/2 a yard? I noticed the weight of this 1 1/2" minus was enough to make the tractor light in the rear end? I was still using the loaner 3130 from the dealer....I figure a yard of 1 1/2" minus at about 2200 #s, So half a yard 1100 #s, does this all sound reasonable? After that I could definetely see why ballast on the back end is so important, even with the tires filled.
Thanks for the reply,
Ryan
   / Yard size of 723 bucket? #4
Most stone & gravels weigh closer to 3000 lbs per yd. Here is a link I use when checking weights. Click Here
Counter weight on 3PH will give you a lot better ballast than loaded tires. It will also move some of the weight on front wheels to rear wheels.
Ron,
Thanks again, I got way overloaded the other day on my dump trailer, the loader guy thought I meant 8 yards, and I meant 8000 #s, I thought it looked awful heavy... It probably was not good for the trailer, anyway I was just wondering because I had to scoop out a lot of the gravel to make the hydraulics on the trailer work and was wondering how much I took out with the bucket....
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
