(yawn) F series hydraulics plumbing?
   / (yawn) F series hydraulics plumbing? #11
that lever under the seat does appear to be an on/off lever for hydraulics. So I think you do have ports on your hyd. block. I'll pm ernie and see if he can take a picture for you of where you can hook up to.
What I dont understand is - if its an on/off why does it have an infinate adjuster - so it can be set half on half off with the wing nut?
But I await ernies answer... :)
Ah - realised an easy way round this - theres a connection from the block to the UFO valve - its a simple short pipe with banjos at both ends - I can replace this short pipe with a long one that does the loader hydraulics.
I still need a single acting port for the tipper trailer - I assume the port above the main under seat 3 point lock off knob is suitable for this?
   / (yawn) F series hydraulics plumbing? #13
Im all a bit new to this, but may be able to help. I have a F18D, and when we bought it, we had a single acting port added for a tipping trailer. This works of the 3pt lever, so when the 3pt is raised to the highest point, the trailer then lifts, and obviously then in reverse.
Im not sure where this has been plumbed into thought, as i havent removed any of the panel work by the seat, and cant trace the pipe without doing so.
   / (yawn) F series hydraulics plumbing? #14
A little late... but here they are.
A Yanmar F20 with a koyker 120 loader, the pictures should answer your questions.
Also there is a YM 1702 with a UFO control on the back, something a little rare for the YM series.
Thanks ernie - it looks like the pipes cut into the system and return into the crankcase exactly the same as my ufo version.
Ill just cut into the 3ph to ufo pipe then.
Thanks for the support..
Guy
Update.
I used the pipe from the block to the UFO valve - I made new pipes up and connected into here. Bad idea. Useless, low pressure and low flow.
Used the side ports - 20mm heavy duty metric thread for anyone reading this in the future, and flipped over the lever to activate it - much better.
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
