Egon
Epic Contributor
Water test and then design the solution.
I don't have much more to offer to help your situation, other than no filter should look like that after 3 weeks, you have something else going on. I am going to ask something disgusting based on the color, is there any chance your water is close to someones septic / leach?
On a personal, yet very disgusting story. We bought our house, the water flowed poorly and was full of iron and smelled. 3 days into having moved in, up shows the Sherrif. He informs us that it is beleived someone is buried on the property. We take it in stride.
Well, two months down the road, the neighbors make an appearance. We talk about all things, including the previous owner who was a bad dude. They tell us that the had killed his partner, and shoved body parts down the well. My wife begins to heave, and I stare blankly at the neighbors. In about 30 seconds I recover and am able to explain to both my wife and my neighbors it is not possible, the well head is only 1.25" pipe, and the hole is maybe 4" max. Unless he of course ground the guy up.
It was just the lack of use, and the usual debris falling in. A bit of pool shock and a day of bottled water and we were back to normal.
Heavy rains where livestock are near could be coliform (been there/done that...it turned the toilets black in a short amount of time). We dealt with it not knowing until we sold the house and had the water tested. Simple water testing should pinpoint it.
black residue like that indicates Manganese in the water. That accounts for the smell also. If you don't mind changing filters often, you can get the smell out cheap and easy. Install a brass air injector fitting into the line coming up from the well. Mine has been in place 25 years without a problem. Any local well man or plumbing supply house should stock the air injector.
YesDeere, Canada Goose season opened here Sept 1st....5 bird limit. My Chessie is raring to go, but I just can't bring myself to hunt in 85 degree weather:confused3:
They let us go wide open on the residents here. No plug and all. My hunting season is on hold, got a new baby coming any day.
Late season it's on though!!! Just loaded up on 4's
Wow, must be chancy being a resident in MD. :laughing: Best wishes on the new arrival.
