YM 1401 Brakes
   / YM 1401 Brakes #11
Where did you get your shoes? Have never heard/read of that problem.
Hoye. I contacted them and Aaron was aware of the size difference. He said you would have to grind the shoes, or turn the drums. It probably doesn't matter but my instincts lead me to prefer to turning the drum. The new shoes have much less abrasive material than the originals - they are not going to last as long straight out of the box and your'e going to have to take at least? a 1/16th of an inch off that.... As you pointed out though, its a tractor not a race car. If the old shoes lasted 30 years is it a big deal if the new ones only lasted 10?
   / YM 1401 Brakes #12
I don't want to go looking for it but I think I remember someone else having trouble getting new shoes to go in.
You can say that again!!!
Why does this stupid forum software double post like 6 years after they swapped the software??? They still havent got the bugs out. NO other forum i am on does this unless its a person on a phone with bad signal and they hit post twice as they cant tell if it went though.
   / YM 1401 Brakes #13
That turns a simple brake job into a train wreck. Hoye needs to address that issue. Would much rather get old shoes relined.
   / YM 1401 Brakes #14
I know places do this still but as a consumer do we have an option these days to have this done anywhere?
   / YM 1401 Brakes #15
And the brake shoes are not cheap!!!! i would think you could have them relined for the same or less....if there is a place that still will go one off sets?
   / YM 1401 Brakes #16
If I remember correctly the linings on the original shoes were dovetailed on, not riveted. Does that make a difference when re-lining?
   / YM 1401 Brakes #17
I am honestly too young (33) to know much about that. I did work on an auto parts store and do all my own work on all kinds of things (yes i know how to do drums and shoes). We had some reman shoes that were bonded and some rivited. I think they can bond the material? But like i said i am no expert on it.
I do know many of the old automotive trade specialties have gone by the wayside with cheap china throwaway parts. And there is no longer the machine shop in every town that does heads and engines. Hard to find a starter/alt rebuld shop and even harder to find a radiator repair place now a days!
   / YM 1401 Brakes #18
You do not remove the friction material. You remove a little bit off of the metal pad that rests on the cam.... if needed. You can use a file, die grinder, or hand grinder. It is an easy job and takes less than a minute. It is pretty uncommon to need to do that but it does happen occasionally if the circumstances are just right. Some linings are extra thick for some reason (see below).
Unfortunately, this is just another case where there is just not enough demand for a product. There is just one company having these made and we are at their mercy. The quality is fine for what they are but could certainly be better. They function just fine and durability is fine but there are some irregularities with the initial fit. I just don't have the budget right now to get a few thousand shoes made that fit only 1 model. The minimum production run would last us about 60 years. :)
   / YM 1401 Brakes #19
   / YM 1401 Brakes #20
That makes a lot more sense to remove metal where they mount on the cams vs grinding the lining!!
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
HARDEE 16' T/A TILT TOP TRAILER (A58374)
HARDEE 16' T/A...
WACKER NEUSON LIGHT TOWER (A58216)
WACKER NEUSON...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2017 ford fusion (A56859)
2017 ford fusion...
