YM 1700 cylinder sleeve
   / YM 1700 cylinder sleeve #31
Never pulled liners but have pulled a few harmonic ballencers and flywheels on boats and such and the constant pressure, spray lube and a whack of a hammer every now and then seeme to what finiallly "pops" them free.
I had a boat flywheel that i was scared i was going to damage the crank pulling any harder than i had it, so i let it sit, sparyed it again and tapped it a buch with a hammer. Then the second or third day i got home gave it a whack and ping it popped free.
   / YM 1700 cylinder sleeve #32
Last motor I replaced liners on was a Ford industrial 3 cyl gasser 201ci (or something about that size) in a Davis trencher did them in frame. Anyway they were pretty big cylinders made it easy to weld inside of. I worked my rear off on them with a plate I made that fit the bottoms real nice and finally mig welded some large lug nuts about half way down inside the liners and pounded them up from the bottom. Once I got them moving they went real easy went back in nice too.
   / YM 1700 cylinder sleeve #33
I'm in process on a full rebuild of my 336d. It had set in my yard since 2007 and somewhere else before that. Lots of rust inside everywhere except the rod and main journals. I pulled the liners yesterday using a piece of 3" pipe and a hammer. The block is completely stipped down and on the floor so it made it easy.
   / YM 1700 cylinder sleeve #34
hi
I just pulled (?) the sleeves on a ym155d and it was the worst job I have done in a long time. The puller was like those shown on this site, but even with ice and heating the block with a dryer it wont budge. I found that the only way to get them to move was to add tension on the puller and then hit the sleeve from the bottom with a piece of steel and a sledge hammer. Your consolation will be that you will be getting out and under the tractor at least 50 times so you can forget your sit ups for a week after.
Tired Gpa Bill
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
LOT LOCATIONS (A52576)
