I hope this doesn't sound like preaching, but I feel like I need to add something to my previous post. Please take the other's advice and get a ROPS, whether you decide to use it to launch the boat or not. Make sure everything is in good mechanical order. Also please wear a life jacket anytime you are in a boat or around the water. Those inflatable ones are compact, light and cool, and I wear mine anytime I am in the boat, and require my passengers to do the same. I used to do Search & Rescue and it should have been called Search & Recovery, because that was what most of the calls were. I also so unexpectedly got thrown out of a boat as a passenger going about 35MPH. If I had not have had a PFD on I probably wouldn't be here now. I will soon be pulling my boat out from under the shed and using the lift to pick the front up so I can wash it out easier. I am confortable pulling my larger boat with a larger tractor because I know how it feels. IMO thats really not that big of a boat, and the tongue weight should be well within the capablility of the tractor. I had thought about BruceR's comment about mounting a hitch on the front of the tractor. You could mount a 2" receiver and change to different drawbar heights as necesary, but may reduce traction when pulling it out since the wheels will be turning backwards. I did that many years ago on a Sears Garden tractor (lawnmower) to put my first boat under a very tight fitting shed. If you decide to do this, trust your feelings, and if something doesn't feel right just stop. Saving a hundred dollars of gas is good, but it isn't worth your life. When things go wrong, it happens fast.
