YM155D issues: maybe head gasket, maybe radiator, maybe?
   / YM155D issues: maybe head gasket, maybe radiator, maybe? #21
As a collective on this forum we can solve almost anything anyone can come up with due to the knowledge of many individuals that make this a great forum to be a part of. This is the best forum for constructive help and knowledge that I am a part of and I'm on many forums and groups :thumbsup:
   / YM155D issues: maybe head gasket, maybe radiator, maybe? #23
Tstats can just be tested in water. Usually, (at least on autos), the opening temp is stamped, 170-190*. If not open by boiling time, pitch it. Temp gauges and temp lights require different sensors.
   / YM155D issues: maybe head gasket, maybe radiator, maybe? #24
I was thinking I hadn't seen that item yet. Then looked at his posting date!!! It's today!! No wonder why I had not seen it. And I was even on their website yesterday!
Happy to report I had a fantastic weekend with my tractor, finally able to relax and enjoy the ride a little and not worry about things so much. Regarding the overheating, I think the biggest thing has been to just slow down, rely on torque and not power, and not overload the mower/pto (RM42, which after all is a finish mower and I'm kind of using it as a brush hog). Coming uphill in Low-3 instead of High-1 has been a game changer, and there's been very little black smoke and no spit from the radiator overflow. Cetane has also been wonderful in getting the engine started like a dream.
There are likely still some issues that I need to sort out but as long as I don't ask too much of the machine for now I've got time to sort it all out. Over the next few weeks I'll check valve clearance, t-stat, and keep looking for signs of a leaking head gasket. But it's a great feeling now that I'm not convinced my engine is about to crack anyday now :thumbsup:
Thanks for the all the help, this place is great!
PS have NOT hooked up the temp gauge. Maybe mine will stay in the box too. But I do need to test the temp warning light still! And change that darn hydraulic fluid.
   / YM155D issues: maybe head gasket, maybe radiator, maybe? #26
See Winston's post #15 above. That's a simple tractor, there's no thermostat.
It is a good idea to check valve clearance (and head bolt torque while you are in there).
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
24" X 32" X 60" METAL ROD CABINET (A58374)
24" X 32" X 60"...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2014 Ford F-550 (A55973)
2014 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
