SailorBob
Once you insure that you do not have any issues with the battery or electrical connections this is the procedure that I use to cold start my 1700. It always starts right up:
Pull the throttle back approximately 50%, press in the clutch, turn the decompression lever to the left, turn the key and allow the engine to turn over for about 10 seconds, release the decompression lever. I should then fire. Once the engine starts adjust the throttle to about 1200 rpms to allow the engine to warm up.
By the way my tractor does not have a thermostart. I have started it down to about 30 degrees F. It seldom gets much colder here.
