Ym1720 won't crank or start
   / Ym1720 won't crank or start #11
Alright so I made sure everything was in neutral and ran a wire straight from the battery to the starter. The solenoid clicked but nothing else. I checked the clutch safety switch and it was fine
What size wire? You need something big, like your jumper cable. Lots of amps involved.
   / Ym1720 won't crank or start #12
Sounding like it's your Battery's Ground. Had the same problems not long after I bought my Ym2000. I had to replace the Neg. cable from the battery to the Frame it was so bad. That kept it going for a couple yrs. then my starter just plain wore out. It was only 75.00$ to rebuild it with a new solenoid. I would pull the starter and have it checked. Most any auto parts store will check it for you. May just be the Solenoid. If the starter works and checks out fine, Then I'd be replacing the Cables.
Alright so I used a bigger wire and was able to get the starter to crank a little bit but it kinda it made a grinding sound and then stopped again. I'm leaning toward starter, I pulled it off and I guess I'll have it tested. Any other thoughts?
   / Ym1720 won't crank or start #14
over the weekend the starter on my YM sound the way you are describing ( grinding noise ) a few times and then would not crank, I did the usual troubleshooting as mentioned to no prevail, took the starter off to bench test, found the bendix is kicking out but not spinning fast, I noted it barely turning, ( grinding noise)
Looks like time for new starters for both our tractors,
Yeah I had mine tested at the auto parts place, and they said it failed. I checked locally and no one would rebuild it so I ordered one from hoye.
   / Ym1720 won't crank or start #16
My research turn up new ones on ebay for around 80.00 free shipping, so I'm ordering one off there,
   / Ym1720 won't crank or start #17
Was it 100% the right one? A few guys have bought them to find that they were not compatible ( ie 9 teeth instead of 11 or vice versa) but if it is right that's a great price.
   / Ym1720 won't crank or start #18
No I'm not 100% sure, I guess I should find out, I assumed by it showing the different YM models these starters would fit my 1700 was included, But after going back to read more about them all I could find it stating was for the 3 cyl; marina engines, another ad that was quite confusing showed 11 or 15 teeth starter to fit our ym1700 through ym2000.
I guess I'll count the old starter teeth to determine which It has before ordering,
Thank you for bringing this to my attention Neat 1500,
   / Ym1720 won't crank or start #19
DND. There's a place in town that rebuilt mine on 5/11. PM. me and I'll give you the PH.# Had it back in 2 days. It was worn slap out and they commented they new someone was in it before.;) Guaranteed and cheap and haven't had the first the first complaint. I still use a 8yr. old battery and looks like there's no reason it will make 9. Your 1700 uses the same starter as a YM240. So that is what I would tell any repair shop it came off of. That way it's a US. JD. Yanmar and not a Grey that they may not be able to get parts for.
2003 Ford E-250 Passenger Van (A56858)
2003 Ford E-250...
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A58376)
UNUSED FUTURE CAT...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Hays LTI PTAT180RD Seed Tender (A57148)
Hays LTI PTAT180RD...
2025 X-pro Mini Dirt Bike (A56859)
2025 X-pro Mini...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
