YM2000 piston. I think I found my running and starting problem
   / YM2000 piston. I think I found my running and starting problem
I did just push it out with my hand from the bottom, you think that would break it?
Also, there is not enough rim on the edge to catch on, I mean I can not catch a finger nail on the rim.
I received my new piston, rings and head gasket today and installed them.
Put all the fluids in and sat there ready to start the tractor and do an initial break in.
I pulled the thottle back half way released the valves to let the oil pressure build, then I let it loose and all I got was little tiny puffs of smoke. Man was I irritated. Then I realized I had only hand tightened the fuel lines going to the injectors (doh). I tightened them up and tried to the sequence again.
Sucker fired right off.
It seems to have fixed the problem.
Just a side note, the guy I bought the tractor from must have broke the piston in the install, the idiot also put the head gasket on upside down blocking two of the water passages. The bolt on the head seemed very easy to untighten also (I am guessing he did not use the correct torque settings).
   / YM2000 piston. I think I found my running and starting problem #13
Glad you got it sorted out.
Sounds like the previous owner was quite the mechanic.:rolleyes:
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
UNUSED ALLMETAL K0311-10' GALVALUME STEEL (A51248)
UNUSED ALLMETAL...
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2023 AGT Topcat Mulching Head (A51573)
2023 AGT Topcat...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
