Ym2000 rpm speed for finish mower
   / Ym2000 rpm speed for finish mower #11
The battery had hit it and all the fins on the bottom half are smashed.
So long as it holds water that isn't critical. You can straighten the fins and it will work fine. The HVAC trade even has combs to make them look parallel again.
Hoyetrator lists a YM2000 radiator for $285.
Another alternative is a radiator shop can put a new core between your upper/lower tanks.
   / Ym2000 rpm speed for finish mower #13
hey he's not half as longwinded as me! :D
Just more scatterbrained and I don't organise my thoughts all togeather in as well organized post as you make.
To the original poster. Your dis tick in the one by the shifter between your legs when sitting on tractor. It's on top of the trasmission. It says "oil and the Japanese word for oil on it". Use JD303 spec fluid. Often times just labeled 303 fluid on the pail. It will take about 4 gallons of it so buy the 5 gallon pail. You may as well change it cause you need to drain about 3 gallons or so when you do the seal. If you don't it will just pour out when you pull the cover off that holds it. So just plan on changing it. You can find it on sale at TSC for $21 (saw that sale 2 weeks ago for a pail ) and regular like $30. There is a filterrible screen on the front bottom side of the transmission behind a plate held on with 3 bolts. Take that cover off pull the screen, it's just fine stainless mesh. And wash it in diesel fluid or gas or something and reinstall it and some rtv or a gasket or both and then do your seal and collar and then refill and go.
I have done both sides. It's not a bad job . It only took about 18 months or 2 years between the 2 when they started leaking so if funds and time allows consider doing both. Otherwise you will need to drain your fluid 2x which that second time if you hAve a clean bucket you can catch and reuse it, but really just easier to do it all at once.
   / Ym2000 rpm speed for finish mower #14
Cool , I didn't realize they had a fun comb. You learn something new all the time!! :)
Millermatic Vintage CV DC Welding Power Source/ Wire Feeder (A59225)
Millermatic...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
2018 John Deere Z997R (A53317)
2018 John Deere...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
7ft Workbench (A57454)
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
