YM226 Power Shift $2750.00 ???
   / YM226 Power Shift $2750.00 ???
Yea I hope it is "bullet proof"!!!!!! I'm going to do a lot of checking it before I put it to any heavy use... Woman just called and said she was on the road. It is now about 6:30, so she will be here in about an hour and 1/2 .... Of course you guy know I will have to wash it and POLISH it before I post any pictures,,,, I think!!!!
   / YM226 Power Shift $2750.00 ??? #12
power shift will be a little slow taking off at times. Once the fluid is warm & circulating it seems to work better
Yea when I took it off the trailor just about 30 min ago, it seemed to be a "little" slow in first gear. Once it got going and I shifted it "went". But your statement does make me feel a little better.... thanks....
I guess tomorrow I will have to work on my outboard motor, the parts came in and need to get it going and GO FISHING!!!!!!
   / YM226 Power Shift $2750.00 ??? #14
Good Luck with the new Toy. Sounds like you got a heck of a deal.
It definately sounds like you are happy with the purchase.
Be careful and work safe
   / YM226 Power Shift $2750.00 ??? #15
Kenmac mine has never been slow when it is cold.Same speed cold or hot.
Yea Gizmo!!!! That is why i just ordered a set of manuals for this thing.. just in case i have to go in it... I'm wondering!!!!
Also got a YRM 60A MOWER WITH IT. It works fine, good belts and new blades. Cleaning it up now... Yanmar mower.....
   / YM226 Power Shift $2750.00 ??? #17
Giz, mine is a little slow when I 1 st start it up. not real slow but, enough to notice.I may just need to clean the hyd. screen.. Are u using ATF fluid or hyd. fluid ?
I ordered manuals for this tractor. Am going to wait and get them to read up on changing lube and how to clean the screen, and what fluids to use. Changing oil I pretty much knew..
My tractor ### on the motor is 3T75H
Fram: CAK 530 air filter
NAPA: 1568 oil filter
I hope cleaning the screen and changing the fluids helps my tractor. I doubt if it has ever been done. Looked like the original air filter to me. 750 hours!!!!
It sure did run better with the new air filter.
I am located about 13 miles north of Rocky Mount, NC...
13.6x16 rear turf
25x8.50 front turf may want to change to ag tires, not for sure.... these big tires seem to do good on this hill I live on..... yall have a good day...
GMAN!!!!!!!11
1269 (A50490)
1269 (A50490)
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
19?? Asphalt Roller (A52377)
19?? Asphalt...
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
