You have gotta see this .
   / You have gotta see this . #11
Very interesting. Scary that a dragging brake can set this off. I wonder if driving on a severely under inflated tire will do the same thing.
   / You have gotta see this . #12
Wow, who would have thought from 2-3 seconds of welding.
   / You have gotta see this . #14
I don't think that would create enough heat in the rubber to start the process. A seized bearing on the other hand can create enough heat to start a fire or get red hot.
   / You have gotta see this . #15
So your car catches fire and there's no telling when the tires may explode. You weld on your rim for 2-3 seconds and the tire blows 2 minutes later with no visible warnings from the tire before it happens. You know it could happen so you deflate your tire. but leave it on the rim and the pressure makes it reseat and blow up anyway.
spooky, spooky, spooky
Wonder what else besides a tire would do this?
   / You have gotta see this . #16
My stepdad owned a tire shop when I was a kid. There was a hole in the ceiling above the tire changer that was perfectly round. His "boys" claimed they had no idea how it happened.
Big tires are no fun to work with.
Thanks for posting that video...who woulda thunkit!
   / You have gotta see this . #17
Split ring wheels, alot of people killed by them, I had them on an old Dodge and the shop I went to for changes had the holes in the ceiling. most dangerous when they are re-inflated seating the bead and ring.
JB.
   / You have gotta see this . #18
Ever run over a road gator?
Most people think those are caused by failed retreads. Not true. Take an up-close look some time. You'll note that they generally include the wire as well as the tread material.
Most (possibly all) blowouts on truck tires are caused by running under inflated and overheating the tire.
   / You have gotta see this . #19
Excellent point. I have noticed the tire cords sticking out.
   / You have gotta see this . #20
I did have a couple tires blow because of failed retread, I never would put a retread on the front, at the time most would not. This was on a big rig.
I do agree a lot of blowouts can be because of wrong pressure, but not all or even most. I had tires blow because of foreign objects {biggest problem} and bad retreads. This was back in the early 90's so maybe things have changed, and even though I used retreads I HATED THEM! Cost was the only reason I used retreads and I NEVER would use them on the fronts.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Kubota B21 (A57148)
Kubota B21 (A57148)
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
