buickanddeere
Super Member
I should have bought a new mower years ago. The last few years have required New coils, ignition module, battery, starter, control module, carb, four tires, three spindles, belts and now this. 1996 LX188
Deere.
Don't if we should try welding the oil soaked aluminum or grind off the broken casting and oil fill from the side of the engine. Drill, tap and install a generic valve?
While I was posting this topic , the eldest boy called and said the truck started blowing antifreeze while trailing but the coolant temp gauge showed normal.
It not even noon yet.
Deere.
