Mowing YRM 60A YANMAR MOWER
   / YRM 60A YANMAR MOWER #1
NCGMAN
NORTH CAROLINA
YANMAR
Anybody got any experience with these mowers?? When I purchased the YM226, this mower came with it. Well I hooked it up and it worked ok, so I decided to kinda restore it. Stripping it down,, tough job,, everything is frozen up. Well I only had to retap one hole, plus using a whole can of lubricant. One of the bearings sounds a little to noisey to me, so am going to remove it and see if I can get one. On the Yanmar plate, it says manufactured in the USA.. Let's see if Napa can match the bearing!!!!!
The blades are new... Now that will probably be an experience,, getting blades for it....
   / YRM 60A YANMAR MOWER #2
I have the OEM bearings & Blades available.
Danny
Might not be able to get the blade off. Have worked on it for about four hours,,, heating,,, hot, hot, hot,,, WD 40 -- one can!!! air impact !!!! Has not budged. Do you have one of these???
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
(INOP) CHEVROLET C-50 GRAIN TRUCK (A52708)
(INOP) CHEVROLET...
6' LANDSCAPE RAKE, 3PT (A52708)
6' LANDSCAPE RAKE...
LOT: Assortment of PVC Pipe (A59076)
LOT: Assortment of...
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
