Yt 359 steering
   / Yt 359 steering #1
chevyman29
Bham AL
JD 2520
First let me start off by saying overall I'm really happy with this tractor.
But , has anybody figured out the fix for the steering ? If the front wheels are in the least bit of a bind it just won't turn .
Or if you have a load on the bucket .
Yes the front tires are filled with liquid. No squatting or half flat front tires.
Also it doesn't matter if the RPM is idle or wide open .
The least bit of a bind or a load and it's just not turning if your sitting still.
If I didn't have a jd 4520 sitting next to it that works fine I might not think nothing of it.
Dealer was no help .
I read about the issue from someone on this site , but I noticed it didn't seem to be wide spread.
   / Yt 359 steering #2
I have 18 hours on mine, and easily 14 of it doing loader work moving heavy wet clay and 57 limestone. I have not experienced any issue with the power steering
   / Yt 359 steering
I appreciate the reply . Thank you.
That gives me hope that maybe it's something simple on mine.
When I get home I'll post up a video showing the issue
   / Yt 359 steering #4
my yt 347 does the same thing.
   / Yt 359 steering #6
I’ve had my YT347 for over 5 years and it has happened a few times to me. I alway have 1k lbs ballast on the back, maybe that prevents it.
Thats not my main issue with the tractor, it’s the frequent regens.
   / Yt 359 steering
That's a good point about the ballast wich I'm a firm believer in.
I've not had a Regen yet . But I've got maybe 20 hrs.
One thing I noticed the other day while using the auger , the boom on the auger will hit the rear remote valves if you lift it all the way up. Just by sheer luck I didn't kill mine the first time I raised it.
Just poor design on the placement of the valves.
Quick Attach Mini Hydraulic Hammer (A44502)
Quick Attach Mini...
New/Unused Hydraulic Pallet Forks (A44391)
New/Unused...
Giyi Quick Attach Pallet Forks (A44502)
Giyi Quick Attach...
2017 Ford Focus SE Sedan (A44572)
2017 Ford Focus SE...
2006 Jayco Trailer, VIN # 1UJCJ02R761SU0073 (A44391)
2006 Jayco...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A43004)
2019 INTERNATIONAL...
