Mowing (Zappator) V belt double drive pulley broken on Kioti CK20S HST
   / (Zappator) V belt double drive pulley broken on Kioti CK20S HST #1
SiOwen
Willaston
Kioti
I own a Kioti CK20s HST, i bought it second hand in Cheshire, i've had a few problems with it such as hydraulic oil leaks, but that was an easy problem to fix, have also sharpened the blades myself, however now when i mow the paddocks, the middle blade will not move, i have taken the deck out and disconnected it from the tractor, and have found out what the problem is. The V belt double drive pulley is broken, the thread has worn out, and the nut has slightly bent too, i've managed to take it off with a 41mm ratchet, however i dont know if i should just re-thread the bolt or get a new double groove pulley. IT may be something to do with the spindle assembly too?
   / (Zappator) V belt double drive pulley broken on Kioti CK20S HST #2
Does the shaft rotate freely in the bearing?
There are three blades on the zappator deck which are all connected via V belts and pulleys, the two outer blades will cut perfectly but the middle one wont as it has come loose from the plate, but the thread on the bolt has worn off so it cannot be tightened, but the actual plate itself does spin in sync with the outer blades. The part i need is a double groove drive pulley which connects the drive shaft to the movement of the bades
   / (Zappator) V belt double drive pulley broken on Kioti CK20S HST #4
Have you been to the companies web page (zappator) yet. I do not have this style of deck for my CK20 so I can not be of much help.. sorry :(
Rancho
Amkus Rescue System (A46683)
Amkus Rescue...
2009 Audi Q5 SUV (A46684)
2009 Audi Q5 SUV...
2025 Swict 66in Bucket Skid Steer Attachment (A46683)
2025 Swict 66in...
2012 TEMPLES TRAILER SALES INC FLARE STACK (A47001)
2012 TEMPLES...
John Deere WHP36A (A47307)
John Deere WHP36A...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A45336)
2018 Generac...
