ZD 326 Fuel Filter Change
   / ZD 326 Fuel Filter Change #1
Rory_Rhodes
Georgia
It's that time. I need to change both fuel filters on my ZD326, but am concerned over bleeding the fuel lines afterward. Any tips? If it's i the owners manual, I cannot seem to find it. Thanks!
   / ZD 326 Fuel Filter Change #2
I changed them when it coughed and didn't run. I was told 99% of the time it is always the filter on the tank side...the first one that sees the fuel, and that the other one seldom is a problem. I did replace both.
I simply turned off the fuel, had a can catch the diesel in the line, replaced filters and it started right up with just a little cranking. It really wan't much of an issue.
   / ZD 326 Fuel Filter Change #3
the fuel pump in between the two filters will refill them its not a problem at all
   / ZD 326 Fuel Filter Change #4
you wont have to bleed them because it has an electrical fuel pump just turn the key on once your done an you will beable to hear thr diffarance in the pump
Utility Trailer (A45336)
Utility Trailer...
12V Diesel Pump Meter And 50 Ft Hose (A44572)
12V Diesel Pump...
2010 UTILITY 53X102 DRY VAN TRAILER (A45677)
2010 UTILITY...
2007 PARK SEPARATOR (A47001)
2007 PARK...
2015 Skyjack SJ86T 86' Manlift (A45336)
2015 Skyjack SJ86T...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
