ZD1511 26x12-16 rear tires
   / ZD1511 26x12-16 rear tires #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I mow a very steep bank Horizontally on my farm.
I’ve rolled one tire off the rim 3 separate times in the last two summers .
Very scary ride until I get stopped.
I know Kubota has a monopoly on these.
Has anyone found anything with a 6or8ply sidewall ?
The cheesy 4ply blew the bands out of the bead this time so off to the dealer I go for OEM 26x12-16
   / ZD1511 26x12-16 rear tires #3
Bet that was a load of excitement.
I hear you about the scarcity of that tire. I had hoped that other manufacturers would bring some to market, but that hasn't happened over the past 3 years. What about swapping the rims and using the widely available 26x12 tires? I was going to look into the tires height difference, then got a great deal on a new set of tires and rims in the newer 16" size.
I've never had a failure like yours, but my slope mowing is limited to about 300 yards of residential banks. I do burn up the rears every 500 - 600 hours by running a lot on residential streets.
  • Good Post
Reactions: JJT
If the tires on 12” rims was the same height : they should work.
I’ve heard Kubota went with the low pro sidewall 16” so mower wouldn’t bounce on rough ground causing blades to cut uneven Idk
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Galvanized steel fence (A53424)
Galvanized steel...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
Toro Zero Turn (A50324)
Toro Zero Turn...
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
