ZD25F No Start
   / ZD25F No Start #1
MarineScott
I posted this on the general repair thread.
I am working on my neighbors Zd25F mower for a no start. The starter was the initial problem, replaced the starter, the battery was half full and was topped with distilled water and charged. Fuses good , voltage at the glow plugs, ohm tested glow plugs, fuel filters were change, fuel was drained and refilled fresh. battery was tested after recharge and tested good. I am wanting to know if the battery is not completely 100% even though tested as so and not turning the starter fast enough. There is lots of thick smoke when trying to start. The starter initially spins faster at the first try of starting. I am not familiar with diesel engines, but I am mechanically inclined as my occupation is an automotive tech. This was running in the fall when put away for the winter and was serviced in the fall. I also have fuel at the injectors when bled. Stumped:confused2:
Any help is appreciated Thanks Scott
   / ZD25F No Start #2
If you have fuel, constantly, at the injectors..I'd have a good look at the glow plugs. I had this issue on a Suburban once...Not my Kubotas though...Fuel filters are good?
Batteries can wreak havoc too...Make sure that's not limping.
   / ZD25F No Start #3
Is the fuel shut off working in both directions? sometimes they get hung up a little bit, as you cycle the key you'll hear the clicking it makes should be on right side of engine. Also check for bad fuel maybe.
   / ZD25F No Start
For those who gave their input to this "no start" problem, it was found to be one of the cylinders was dead and the other was on its way out.
Thank you for all your help!:thumbsup:
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
iDrive TDS-2010H...
3410 (A47477)
3410 (A47477)
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
