mchildress
I received this from Customer Satisfaction@Kubota com today.
Dear Sir:
The differences you mentioned below are the only ones between the two
models. The engines are the same and the transmissions are the same.
However, the gear ratio is reduced on the ZD326S to match that of the
ZD321, that is the reason for travel speed being lower. There are no other
differences. Thank you for your interest in Kubota!
Your Original Inquiry:
I am wanting to know the spec. differences in the ZD 326S and ZD 326P. I
have found the 326S does not have the run flat front tires and the speed is
0-9.4 vs the 326P speed of 0-10.6. Is there transmission difference for
they both have the same engine (D1005)or any other spec. differences?
Dear Sir:
