Zetor 5245 where the implement lift not working
   / Zetor 5245 where the implement lift not working #1
simonbrodin
Sweden
Hi, I have a Zetor 5245 where the implement lift not working, bucket works fine so nothing wrong with the hydraulic pump, the pump is new and are working, please help me out the snow is falling down
   / Zetor 5245 where the implement lift not working #2
Check your QD's
Disconnect them and reconnect.
   / Zetor 5245 where the implement lift not working #4
I believe JJ means the quick disconnects of your hyd. hoses
Im sorry it is the arms in back of the traktor
   / Zetor 5245 where the implement lift not working #7
Then check your descent knob under the seat.
It is used for transport or to adjust the lowering speed.
Clockwise will lock it for transport.
Counterclockwise to adjust for speed of descent of the 3pt lift arms.
The hydraulic pump is not even running when I'm moving the stick for lowering/raising, but do work when I'm using front implement like the shovel
   / Zetor 5245 where the implement lift not working #9
Usually, the hyd pump is running when the engine is running.
Do you have one or two pumps.
Do you have a way to shut off the pump?
   / Zetor 5245 where the implement lift not working #10
That would be my first check also, good luck !
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54756)
PALLET OF 2" X 4"...
Charlotte County (A50323)
Charlotte County...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 Jeep Patriot Sport 4WD SUV (A55758)
2013 Jeep Patriot...
