Zetor 5245 where the implement lift not working
   / Zetor 5245 where the implement lift not working #1
simonbrodin
Sweden
Hi, I have a Zetor 5245 where the implement lift not working, bucket works fine so nothing wrong with the hydraulic pump, the pump is new and are working, please help me out the snow is falling down
   / Zetor 5245 where the implement lift not working #2
Check your QD's
Disconnect them and reconnect.
   / Zetor 5245 where the implement lift not working #4
I believe JJ means the quick disconnects of your hyd. hoses
Im sorry it is the arms in back of the traktor
   / Zetor 5245 where the implement lift not working #7
Then check your descent knob under the seat.
It is used for transport or to adjust the lowering speed.
Clockwise will lock it for transport.
Counterclockwise to adjust for speed of descent of the 3pt lift arms.
The hydraulic pump is not even running when I'm moving the stick for lowering/raising, but do work when I'm using front implement like the shovel
   / Zetor 5245 where the implement lift not working #9
Usually, the hyd pump is running when the engine is running.
Do you have one or two pumps.
Do you have a way to shut off the pump?
   / Zetor 5245 where the implement lift not working #10
That would be my first check also, good luck !
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
gravely riding mower (A55758)
gravely riding...
2008 Cat D4K XL Dozer (RIDE AND DRIVE) (A50775)
2008 Cat D4K XL...
