ZTR/ Lawn Tractor Under Deck No Stick
   / ZTR/ Lawn Tractor Under Deck No Stick
My system is probably 'not for everyone', but I simply pull the mower over a small pile of wood chips. Run it for a minute or two, and it's once again sparkling clean.
Interesting. Never heard of that one. A friend who is a small engine mechanic (for years now) drives overtop of a tank of water, lowers the deck then turns on quick, off, on. Claims it completely washes the under deck grass away. But, he cleans large numbers of decks, so has a good setup for this. Not practical for me to do.
Guess I will rely on the old method to get the machine up in the air and clean by hand. Did order a "special deck scraper" from Amazon yesterday. Did not have a heavy duty putty knife.
The wood chip idea sound like it would work.... just don't have an area full of chips to use.
   / ZTR/ Lawn Tractor Under Deck No Stick #12
This really seemed to work for me but it takes some initial effort (after that it lasts for years):
In the off-season remove all spindles, pulleys, etc. from the deck shell.
Sandblast (or at least heavy sanding) the entire underneath of the deck.
Coat with 2 thin coats of this: Rust Preventive Coating
Let dry for a few days then reassemble.
POR-15 is supposed to cover rust but if you get the surface down to bare metal it actually forms a VERY hard and smooth surface (if you are careful about brush strokes) and lasts for years.
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
UNUSED RAYTREE RMDM70-70" HD DISC MULCHER (A51248)
UNUSED RAYTREE...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
