ZTR search ramblings
   / ZTR search ramblings #11
I cant comment on the Kubota mowers but the Ferris is definitely a smoother rider than others in its class. If you decide on a Ferris be sure to ask for a Kawasaki FX grade engine. The fuel consumption (or lack of ) is phenomenal with the Kawasaki engine. My IS 700Z has a 52" deck with a 23 HP motor and mows twice as fast as my other mower with same size deck and 26 HP B&S engine but consumes about 1/3 less fuel for the same amount of work, some of which can be attributed to faster ground speed but not all.
Find some rough ground to demo all the other mowers on and you can readily see the difference in comfort level. About 3/4 of my mowing is converted pasture which is fairly rough and the suspension helps to smooth out the bumps and make mowing much more enjoyable. I mow about 6 acres in 2.5 hours and have tons of trees and shrubs to mow around.
   / ZTR search ramblings #12
I encourage you to investigate the SCAG Tiger Cat, Turf Tiger, and Cheetah before pulling the trigger on one.
investigate good or bad? I looked at and liked both the turf tiger and the cheetah. I will most likely wait until the spring to buy unless someone knocks my socks off with a deal at the end of the year. I am leaning towards the Kubota zd326 with 0% 60 months payments the payments are less per month than the scags or toro at 0% 48 month
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
40' CONTAINER (A51244)
