Offroad Normand Trailer Purchase
   / Offroad Normand Trailer Purchase #11
I知 still very pleased with the product. Use it all the time in 5 acre vineyard and surrounding 37 acres. I do not go over large objects with it but generally performs well on open land. I woul purchase this trailer again.
Thanks for the reply.
I ended up purchasing the trailer for $2k, which wasn't a steal but it was in excellent shape and I think you'd be had pressed to find anything in this size that is built as solid. I was considering a MUTS, DR Versa or T-Rex type trailer, but I think I'll be happier with this one.
It came equipped with a hydraulic (2 way) dump... the only issue being none of my haulers have rear remotes (yet) so I've been unloading it by hand.
Hysyde - That is pretty close to a steal for the quality of the trailer. What length is yours? This summer I need to free up the latches at the side corners so they operate more freely. There might be a pump option that you can retrofit for the trailer. I know many of these trailers came with either manual pump or hydraulic setups. Congrats.
   / Offroad Normand Trailer Purchase #14
I took measurements when I bought it, but they escape me now. I believe it's the exact same trailer as yours, looking at the pics.
I may try to retro a 12v hydraulic setup from a friend's on-road dump trailer that's rotted out. There's not a lot of room on that tongue though and as far as I know, most 12v hydro dumps are 1-way and use the bed weight to retract.
I'm hoping to just put remotes on something soon....
   / Offroad Normand Trailer Purchase #15
So a friend wanted to borrow the trailer to support some excavation he was doing. He didn't want to use a tractor to dump, so he asked if he could add a 12v hydraulic system off an old dump trailer he had. I was reluctant as he has a habit of cobbling things together in a hurry, but he did a pretty decent job and only welded on the one plate to hold the pump (which fit conveniently under the box) and drilled a couple of holes for the quick connect wiring (power supply and pump controls). The trailer doesn't have much room to mount a battery out of the way anywhere and I told him I didn't want it outside the tongue as I sometimes like to jackknife it. So he decided to use tow vehicle power via booster cables that quick connect to the trailer through a plow harness power supply. It works perfectly with my Kubota as the battery is readily accessible. A battery could always be temporarily mounted to the tongue and he maintained the existing hydraulic hoses and couplers on the trailer if I ever want to hook it to a tractor. The only thing I'd like to see different is the "return" line coming from the cylinder. It's just dead ended with a "vent" that seems to weep a tiny bit of oil (as it's a single action pump). I would've maybe drilled into the hydraulic tank and used a couple to feed it back into there. It works well though and raises fast and comes down relatively good by gravity.
   / Offroad Normand Trailer Purchase #17
If you told me that was factory I'd would've believed you. Going to get spoiled now.. ;)
2015 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
Kawasaki NR (A50324)
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
