QueBota
Gold Member
Not sure if this is the correct forum or title.
Most auto parts stores have one hanging in the nut/bolt area. Different size/thread pitch/count fittings hanging on a cable.
Enables you to check you bolts/nuts against theirs to verify what you have.
Home Depot/Lowes also have them, typically flat mounted in the nut/bolt isle. Normally they are worthless as everyone who has used it has cross threaded/forced the wrong size/pitch/count onto the test fitting.
Would like to have a set on a cable in the shop, would save me a lot of time. Searched online, couldn't locate anything, my search string is likely incorrect. Anyone know of a source?
Have a flat plastic card type, they are useful at times but hard to fit where space is limited.
I must no be the only one looking for something like this, have seen more than one "clipped" off the mount at local Advanced Auto Part Zones, cable left dangling with nothing attached.
Thanks,
Q
Thanks,
Q
