New to me Yanmar 2210D...and I have questions! :D
   / New to me Yanmar 2210D...and I have questions! :D #1
Skold
Member
Sagle, ID
Hi All,
I've gotten a 2210D that came with my new property. It's not in horrible shape but not the best either. I've been searching and researching on this forum and have already learned a few things thanks to y'all! I do want to get to know my tractor more, get it in better running shape, and make sure I'm doing everything right so it lasts me a long time. I want to learn to work on it myself and although I don't know much yet, I'm capable and willing to learn. I do have a few questions up front and I'm sure more will follow. Some of them may even be very basic so be warned. :laughing:
1. The first issue is that the hydraulics for the bucket on the loader are backwards for up and down. When I push the lever forward, it lowers and vice versa. Coming from a Kioti tractor, I know this is backwards and I want to fix it. Would this be a simple swap of the hydraulic lines? Is this something easy to do? I've never messed with hydraulics on anything before so I'll be starting from zero.
2. I want to change out all of the fluids on the tractor and get a fresh start. Rather than cobble together information from here and there, is there a simple place anyone can point me to for what to change and how to do it? I know there's the oil, and hydraulic fluid, but what else is there? Axle fluid maybe?
3. When I let off the throttle, the tractor doesn't want to idle. It seems as though the vibrations are working the hand throttle all the way forward by itself and killing the engine. Is this normal? If not, is there an easy fix?
4. The brake petals are sticky. Is there a known simple fix for this or common culprit I should look for?
5. Range shifter. I understand that this is like a primary gearing system or something, but what gears should I use and when?
6. PTO shifter. I have seen that this is in the H pattern (like range shifter) and I was told that I should only use 1st gear. My labels are totally gone and I want to make sure I know what I'm doing there. I already put it in what I think is first and made a couple of rounds with the PTO brush mower and nothing has broken yet. Any advice here?
I think I'll start with this. I'll attach more pics when I can get some. Anyway, I thought this was a junk tractor at first and especially compared to my Kioti CK4010 that I sold before I moved but from reading on here, I guess it might not be so bad if I can get it sorted out and take care of it.
Thanks in advance for any input and help!
   / New to me Yanmar 2210D...and I have questions! :D #2
1. I believe forward is correct for lowering but yes, if you want it opposite you could change hoses. However, if your control valve has a float position then changing the hoses might not work. Float position just release all hydraulic pressure on the lift pistons therefore letting the bucket float.
2. Your 2210 will hold close to 5 gallons of transmission/hydraulic fluid. Dipstick on top of transmission for accurate amount. You also have a suction screen that will need to be pulled and cleaned. It is behind a 3 bolt flange on the left side (sitttng in seat) just opposite of the hydraulic suction line that goes in on the right side of the transmission. Your engine will hold a little less than 5 quarts of a good rated diesel oil. I use Rotella 15w40, you can get many opinions on the oil. You have a spin on oil filter (wix 51064 is one). Your front wheel drive uses a gear oil. You can use 80w90. Don't know for sure but if you change it it is likely to take close to a gallon. Might crack the bottom plugs and see what comes out. If you looks nasty you might want to change it.
3. I am sending you a pm so you can email me and I will share something with you to shown you the friction washers on your throttle and how it all goes together.
4. Brake pedal shaft may need lubing, cam of brake shoes likely sticking. Many folks have to pull things apart to free them up.
5. I'll let someone else answer this. Just don't lug your engine.
6. Your brush mower is rated for 540 rpm. Anythng over that could be dangerous. Your pto speeds are 547,709,928,1231rpm. I think this is your shift pattern. PTO SHIFT PATTERN _: Yanmar Tractor Parts
   / New to me Yanmar 2210D...and I have questions! :D #3
Winston pretty much covered it. There is a friction washer where the throttle lever pivots in front of your knee. I tried making one, a couple of times. That never worked well. I gave up and bought the proper one from hoyetractor.com.
The rototillers Yanmar sells in Japan for YM2210 can be run at the higher pto speeds tilling muck in a rice paddy. 540 rpm is the universal standard for US-made implements, faster is dangerous. (A few specialized US implements are made for 1000 rpm, but rare). So use only your slowest pto choice.
It is common for the shaft that goes into the brake housing to get stiff from corrosion and from brake dust on the inside. There's an o-ring that prevents lubing it from outside. Its simple to remove the cover and clean up the shaft so it will turn freely. You might want to buy the special brake spring pliers - same as for automotive drum brakes - to make it easier to get the brake shoe return springs back on, although small vise grips and a screwdriver for leverage can substitute. On each side, the front and rear brake shoes can be swapped to average out the wear.
Fluids etc - There are excellent English language manuals for the similar YM240 that Yanmar built for the US market. I suggest buy YM240 Operation Manual on Ebay to get a general idea of Yanmar's design philosophy, advice on operation, etc. YM2210 is a slightly larger and heaver near-twin to YM240 with the Powershift vs manual transmission as the major difference.
If you haven't discovered hoyetractor.com yet - they will have pretty much everything you will need to support this tractor. Their parts diagrams online are the first place to look when you wonder how something is assembled.
Range shifter: Low for rototilling when you want to creep along. Or to sneak up on a pallet to get loader forks under it while standing up to see what you are doing. Intermediate most of the time where the tractor is working reasonably hard. High is 'road gear', also you may be able to mow in high and get more done.
Appearance: Ignore it, unfortunate but it has little relation to the condition of the tractor. That oil filter looks new which is a better clue to the prior owner's care. My YM240 was equally shabby from years outdoors when I bought it, now 15 years later its still ugly but so what.
I would replace that bogus fuel cap immediately to avoid condensation in the diesel. Two choices: first is the proper cap and a mesh screen that goes under it for filtering when you refuel. From hoyetractor. Other choice is a $65 cap with a fuel gauge in it. Ask Hoye if the float in this one is calibrated for the size of your tank.
Most of all, just run it and enjoy it!
   / New to me Yanmar 2210D...and I have questions! :D #4
The way I figure it, a hydraulic lever should work as if the axis and rotation is the same from lever to tool. Sometimes when going sideways, it gets complicated. But to me, push on a joystick and the loader goes down is right. Push joystick to the side, away from me, and the bucket goes away (down).
Sorry, you guys are right...mine is opposite of what it should be so forward is going up. I'll read more of what you guys said when I have more time in the morning but thank you so much for the input so far.
   / New to me Yanmar 2210D...and I have questions! :D #6
Looks like Winston and California have covered everything in good detail! Nice find, and you will love the 2210d:thumbsup:
Hey Guys...this is a wealth of information and enough to get me started. I REALLY appreciate y'all taking the time to answer my questions. I'll go over this stuff and see where it gets me. For now, I at least think I have enough info to attempt a mow of our 5 acres, which is starting to get overgrown. Then, I'll check and replace fluids and parts as necessary, etc. I'll post again here if I have follow up questions but for now...cheers!
   / New to me Yanmar 2210D...and I have questions! :D #8
On #3 if you look at your throttle lever there is a washer/friction plate in between that holds it in place. I'm sure it's on the Dia. winston may have sent and Cali. mentioned. Not much to it!! In the pic. is what it looks like new you can see it. They wear and get old and brittle. Mine fell apart and came out when I tried to Adj. it. The two locking nuts is how you Adj. it and adds tension. Fredricks mailed mine in a reg. Env. Yrs. ago when I just bought my 2000 and I'm sure they're pretty much the same. FP.8220 is the # of it. And just vent the cap to prevent condensation I just posted it and received a good reply well done on it and didn't cost me anything. Came off a old ATV. It's just a tube. Here is the pic. of it while your here.
   / New to me Yanmar 2210D...and I have questions! :D #10
678/447/1802 Spalding
Call this man. He knows or can get anything your need for that model. He may even have one the lot. Bought a couple tractors from him. Fredrick's supplied.
2022 JOHN DEERE 6140M LOT IDENTIFIER 174 (A53084)
2022 JOHN DEERE...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
PRENTICE 12 OC HYD GRAPPLE LOG LOADER (A51246)
PRENTICE 12 OC HYD...
JOHN DEERE 48" REAR BAGGER (A51248)
JOHN DEERE 48"...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
