Hi All,
I've gotten a 2210D that came with my new property. It's not in horrible shape but not the best either. I've been searching and researching on this forum and have already learned a few things thanks to y'all! I do want to get to know my tractor more, get it in better running shape, and make sure I'm doing everything right so it lasts me a long time. I want to learn to work on it myself and although I don't know much yet, I'm capable and willing to learn. I do have a few questions up front and I'm sure more will follow. Some of them may even be very basic so be warned. :laughing:
1. The first issue is that the hydraulics for the bucket on the loader are backwards for up and down. When I push the lever forward, it lowers and vice versa. Coming from a Kioti tractor, I know this is backwards and I want to fix it. Would this be a simple swap of the hydraulic lines? Is this something easy to do? I've never messed with hydraulics on anything before so I'll be starting from zero.
2. I want to change out all of the fluids on the tractor and get a fresh start. Rather than cobble together information from here and there, is there a simple place anyone can point me to for what to change and how to do it? I know there's the oil, and hydraulic fluid, but what else is there? Axle fluid maybe?
3. When I let off the throttle, the tractor doesn't want to idle. It seems as though the vibrations are working the hand throttle all the way forward by itself and killing the engine. Is this normal? If not, is there an easy fix?
4. The brake petals are sticky. Is there a known simple fix for this or common culprit I should look for?
5. Range shifter. I understand that this is like a primary gearing system or something, but what gears should I use and when?
6. PTO shifter. I have seen that this is in the H pattern (like range shifter) and I was told that I should only use 1st gear. My labels are totally gone and I want to make sure I know what I'm doing there. I already put it in what I think is first and made a couple of rounds with the PTO brush mower and nothing has broken yet. Any advice here?
I think I'll start with this. I'll attach more pics when I can get some. Anyway, I thought this was a junk tractor at first and especially compared to my Kioti CK4010 that I sold before I moved but from reading on here, I guess it might not be so bad if I can get it sorted out and take care of it.
Thanks in advance for any input and help!
