MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,461
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Gary, sounds like you understand the hydraulic situation needed. I would use 3" cylinders for the "TnT" on your tractor. I usually look at the size of the lift cylinders on the loader to get the size that works best. You probably need an 8" stroke for your side link and a 10" stroke for your top link. How many remotes are available from Deere? Factory would be the cleanest setup, but 3 may be the limit.
The heavier the better. With all grading implements, weight is your friend.. Buuuut, it sure is nice to have that 30" offset. Sort of need to "weigh" (pun intended) just what you really need. The offset amount would really sway my decision at this time. Please post the cost differences. When I priced mine, the Frontier & Bison were 3-5 hundred more.
