1-3-2-4
Chicago Electric Genrator powering a Chainsaw - YouTube
This guy shows how he was able to get the 800 watt HF generator to run his electric chainsaw. His approach makes sense and I want to try it with our pole saw for the back four since I do not have a back 40. :laughing:
Chicago Electric 800 Watt 2 Stroke Generator Frequency and Voltage Testing - YouTube
I reposted this link from above because it is sure to appeal to the geeks because he does a stress test using VOM and frequency meter. I just used a Kill-A-Watt which I think is a must if one owns ANY generator. He tested up to 1100 watt load.
Not sure why but the manual calls for a 25 hour break-in peroid before pulling 800 watt load. The manual stated it can be used for up to 30 minutes at 900 watts which is good for chainsaw use I would think.
Yesterday I got 10 hours @ 500 watts load and now am on the third tank going for 15 hours total run time. 5.5 hours @ 400 watt load run time in the manual seems to be correct.
Since the happy reviews that have 300-400 hours of run time on their 800 watt HF generators seem to have done the 25 hours break-in time up front I am doing the same. I still have to pick up another spark plug but it started OK this morning after 10 hours on the OEM plug.
Since I mix my 2 cycle fuel at 40:1 and now use Stihl HP Ultra synthetic that is what I am using for the generator. Some other reviewers use the same ratio but the labeled 50:1 ratio on the genset seems to work well per the reviews.
I used my 900W on a 1000W toaster oven for at least an hour with no problems at all..
Harbor Freight 900W generator - YouTube
