VaGlock
I noticed the OP states towing with his Escape, what does the manual state for the Escape's tow rating and trailer brake requirements? I had an older Jeep Cherokee that stated anything over 2000lbs required trailer brakes.
My problem is getting it recognized as legal 3,500 GVWR for legal rating.Most 3500 lb axles have the flange for brakes on them, even if it didn't come with brakes from the factory. You don't need the manufacturer to add brakes. If you have basic mechanical skills and auto electrical (as in, you're capable of changing oil and are familiar with righty tighty, lefty loosy and which terminal to connect a jumper cable to) you can install the brakes yourself.
Tow rating is 3.5K. 2019 Escape Titanium w/ 2.0l.I noticed the OP states towing with his Escape, what does the manual state for the Escape's tow rating and trailer brake requirements? I had an older Jeep Cherokee that stated anything over 2000lbs required trailer brakes.
Not sure how it works in your state. I've licensed over a dozen different trailers in three states and in all cases I told them what the GVW is. They don't check. Besides that, unless you have an obviously unsafe load, trailers that size don't get stopped and weighed.My problem is getting it recognized as legal 3,500 GVWR for legal rating.
^^^. This ^^^Besides that, unless you have an obviously unsafe load, trailers that size don't get stopped and weighed.
The only difference between the 2,990 and 3,500 pounds is brakes. None on the 2,990 trailer.Prices seem to have settled down a bit.
Once again I'm looking for a trailer with an honest 3.5K rating for towing behind my Escape.
Keep turning up trailers called 3500 but with only a 2,990 rating.
Any pointers to ones with actual 3,500 ratings?
His vehicle has a towing capacity of 3500 lbs. Probably doesn't want to use up half of that before he puts a load on.What is your goal? Is there any reason for a 3.5K trailer rather than a heavier duty trailer? 7K?
I'm a big fan of tandem axle trailers (and now experimenting with a triple). Blow a tire and you can safely get to the side of the road, or a place to change the tire.
If towing weight is a concern, look at some of the aluminum trailers.
Also my son who, lives 3 miles from me, has a Toyota minivan w/ a 3.5K GVWR.His vehicle has a towing capacity of 3500 lbs. Probably doesn't want to use up half of that before he puts a load on.
