newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,602
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
One of us has it wrong -GVW is the key item of this conversation. The tow vehicle is rated for 3.5K GVW. That means the trailer weight and load. All is good till it isn't. If you were to have a trailer that could haul 3.5K, you'd be over the tow vehicle specs. So you'd have a trailer that weighed 1500lbs and could carry 3.5K for a GVW of 5K. If it went sideways, a lawyer would make it your fault even if it wasn't! You'd be over loaded with that setup and be on the hook for a lot of items. Even a 3.5K trailer that happens to be over loaded and things go sideways, still your fault. Just want to bring this to your attention before things go south. JM2C.
I'm looking for a trailer that is rated at 3,500 GVWR (as stated in the thread title).
That means a trailer and cargo must be 3,500 or less.It is the maximum loaded weight of your vehicle (or trailer), as determined by the manufacturer. GVWR isn't just the weight of passengers and cargo but also the vehicle itself.
Like others have wrote there is often a limit of 3K for trailers where above that one needs brakes.
The trailer (unless I get Aluminum) will probably weigh about 1200 lbs. So if it has a 2,990 GVWR that would let me carry about 1,790 lbs. Addition of brakes and upping GVWR to 3,490 lbs. will increase my legal carrying capacity by about 500 lbs. That's about a 27% increase, plus in my view a lot safer with brakes.
