milstencil
Member
A little back ground, tractor is a B2910 with a LA402 loader. I have been frustrated for years at having to remove the loader hoses to use the front mount snow blower and angling grader blade. I would like to be able to use the loader and use the other implements without disabling the loader.
I have acquired a complete loader valve, joystick and hoses for the LA403 loader.
My first question is, can I T-off the main feed which comes from the case to my original valve (photo A) and hook up the main feed of the second valve (photo B) to it?
Second, can I route the returns for the second valve to the "option" (photo C) which are the parts for the rear remote option on my tractor?
And finally if this can be done, will it affect the performance of the hydraulic system? I will not be using any two implements at the same time. It would be nice to be able to pick up a load of gravel and grade it out without having to take of the blade.
Any suggestions would be gratefully appreciated.
Rick
Rick
