I own a New Holland LB75.B TLB with a 95 hp turbo-charged Iveco engine. The Operator's Manual calls for an engine oil and filter change every 500 hours. The engine holds three gallons of oil and the filter a quart, So that works out to a bit over 3 gallons with filter change.
I purchased the oil, filter, and a brand new 6-gallon drain tub for the job. After greasing all the zerk fittings on the underside of the tractor, I moved to oil change. The engine drain is a big hex-wrench plug about 1-1/4" in diameter. I figured it would be like my Cummins Diesel in my truck with a wide flange and a small opening. As I loosened the plug the last round and removed it, I immediately knew I had made a big error in judgement. The hole is about 1" in diameter and oil came gushing out like a geyser.:shocked: I realized too late that my engine oil tub's opening was way too small (about 1/2"). There was no way I was gonna catch all that oil. It filled the top of the tub and came spilling out on my cardboard creeper and made a quick path in my direction. I quickly scooted out from under the tractor and only got one arm and one sleeve on my t-shirt partially soaked. Some oil spilled onto the ground, but luckily, most was caught by the cardboard as the gusher quickly came to an end.
I sat there feeling really dumb because I could easily have drained that oil into a 5-gallon container and then transferred it to my oil barrel. Instead, I made a real mess. After getting the oil cleaned up, everything else went normally. I don't know if other engines are like this, but this was the first time I found a drain plug that flowed such a big stream. Wow!:confused2:
