Homebrew,
You never did tell me if the QA cyl went into relief, and therefore was exerting the full force on the cyl rod.
The reason I ask is that if your cyl is a 1 in cyl, and 1/2 in rod, at 3000 psi, that cyl should exert a pressure of 2300 lbs in the extend mode, and 1700 lbs in the retract mode.
Does your three spool valve work well in other functions?
It puzzles me that the cyl could not pull or push past the lugs.
The only way I can see that the hyd would not work is that if the mechanical force, as in a bent plate might put enough force of steel on steel to overcome the pull or push of the cyl.
Hi JJ,
I'm still not entirely sure if the QA cyl went into relief. By the time I read your post about how to check this, I had already unbolted the cylinder and was able to see that I then got full travel. Although this might not have been the brightest thing to do, I also whacked on the stuck pegs awfully hard and they just would not budge past a certain point. I'll try to get a good picture of the bent plate, but there sure was a lot of menchanical binding. I have a new plate on the way at which point I'll get everything re-assembled and see if I can hear the relief valve.
Anyway, I haven't had a chance to get the hyd gauge and fittings to check the pressure, but I would like to do that at some point. I assume the three spool valve has something to do with the three degrees of motion? As far as using implements like the grapple and mini-hoe, I have NOT had any issues or problems. Of course, it's possible that the hyd pressure isn't what it should be and I just can't tell.
All in all, I'd be surprised if this was anything other than a case of simple mechanical binding. I really hit those pegs harder than I probably should have without a hint of movement. As soon as I put the clamp on and straightened the plate, they moved quite easily.
Thanks again for all the help. This will probably sound odd, but having the PT break down can be pretty fun...I'm enjoying the learning!
