mcfarmall
Veteran Member
- Joined
- Oct 1, 2015
- Messages
- 1,484
- Location
- Kalamazoo, MI
- Tractor
- Kubota M5660, Farmall C, JD 260 lawn tractor
50hp 4wd!!
A "properly" weighted 50hp tractor, with GOOD tires will out pull a 35hp MFWD tractor, ESPECIALLY if it's a "utility" tractor, UNTIL the ground get's soft, then everything changes.
SR
I'm not sure why you are saying that??If you are ever going to till your food plot the 4x4 will give you the reduced ground speed needed.
Exactly what my opinion is. In ideal conditions the 50 hp will probably pull twice as hard, but the 4wd will get around much better in less than ideal conditions.
