What do you plan on using the place for later, just a HOME or going to put in some commercial type equipment for welding wood working or grand public race track??? If not doing any of that then single phase is fine.
Rent a BIG trencher and put in the conduit yourself, with the pull boxes at equal distance and in a straight as line as you can. Even if you have to cut thru some switch backs and trench DOWN HILL in steep spots it is better than having to put in a LOT MORE pull boxes and bends. Conduit and Cable is getting expensive as raw materials are up still... Under ground is best way tho as fire, flood, storms etc will not interrupt the wires... Once done keep trail marked where it is at & keep trees from growing up on it as those roots can wrap up and pull it out if tips over.
The underground cable is HIGH VOLTAGE too and as such will require special marking tape to keep people from digging it up later. Use RED (or Yellow) High Voltage Tape (or if local codes require something different ask power company) 1 foot under surface and 1 foot above the conduit. Mark all locations ahead of time for the pull boxes too! that way you can plan out best rout thru/to the transformer pad.
Use SWEEPS for any 90 degrees and ONLY use 3 per run into each pull box at most 45 degrees are better or heat and bend to the desired offset. MAX of 360 degrees worth of bends that includes the 3 to 5 degree bends that are natural when the conduit bends around underground. that is why only use 3 90's in a 300 foot pull they said they can pull 700 feet? if so only use 2ea 90 degree sweeps one for each pull box coming up. OR some are made to mount deep under ground but require above ground access. See what the power company recommends they may prefer something specific for their equipment.
Mark
