Ford tractor
Platinum Member
- Joined
- Apr 7, 2010
- Messages
- 975
I get what you guys are saying, but I just dont follow the logic. I seem to be getting the advice that since heavy equipment is expensive to repair and since most people need it repaired at all costs its okay for the guy to rip me of or over charge.
No exactly. You wrote initially;
The shop called me today and said they think they found the problem. There is one small part in both of the work port relief valves that is worn. They quoted me about 260 a piece for the replacement valves and said they can have them in the morning. The guy told me that labor would probably be about $1000, which seemed high to me. I questioned the estimated amount and he told me that they had about 4hrs in it so far and they would have more time putting it back together. Labor is $87 an hour.
At $87 an hour that's 11-12 hours total labor. They have 4 hours taking it apart, probably will charge you an hour for looking up the parts etc, then probably an hour to assemble and test the valve as an assembly probably on a pressure/flow fixture, 4 hours to put it all back into the hoe and adjust the controls etc, that's about 10 hours there -- right? Then he probably added an hour or so to test the whole machine and make sure it was really fixed. I don't know the shop you are dealing with, the standard procedures they use, etc but the stuff I outlined is fairly basic in the industry for a decent shop.
What I hear is you upset about a quote or estimate not being a firm fixed price and being "ripped off" even before the bill is presented. I certainly could be wrong about that, apologies in advance if that's the case. I do hope you get your equipment back up and running the way you want it to be.
