greasemonkeyok
Veteran Member
Start here:
KY Public Service Commission Consumer Services Complaint Form
If they are like most other regulatory agencies, they will respond best to polite but persistent contact. Remember, they are political, and the electric companies have more contact with them. But if they see that you are going to draw a lot attention to an unfixed problem, they don't like being in the camera field of view.
Several years ago I purchased a couple of "hospital" grade surge suppressors and placed them on both legs of the 220v near the main. That seems to have helped. Two different factors on suppression, how much power (amps) they can absorb, and how quickly they clamp down on the surge. The quick devices usually will not hold very much power, and a lightening bolt has a lot of power.
Oh, and I almost forgot, the more customers with the same complaint, the more likely the regulators will put pressure on the utility.
Finally, if you are going to install multiple ground rods, hopefully one of the hams on this board will educate you about something they call "ground loop." It can cause interference on some devices.
