Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
For moving and leveling dirt that is brought in my one dump truck load at a time, I would use the smallest tractor like a B or even a BX. The more you run your machine back and forth dumping or dragging (using a box blade) then the more compacted it is going to be. I wouldn't get anything bigger than a Kubota B series. They are small enough to get to most spaces, heavy enough to carry more than a wheel barrow full of dirt at a time and with a box blade, powerful enough to drag a good bit of dirt per pass.
If you aren't in a hurry as you posted (1-2 years to do the work) then the smallest, cheapest tractor will work for you and be more maneuverable. I do a lot of work with my B26 and it surprises everyone with how much it will lift, push etc. It is a lot heavier than a regular B series tractor because of the TLB frame and backhoe, but is the same frame and engine size as a B26XX series. Plenty of capability in these tractors for what you will be doing.
Also with a smaller tractor, it is much easier to be precise with your FEL placement.
