I purchased a King Kutter 60" and used it (quite successfully) for several weeks before I found in the manual that the recommended limit is the 48". (YIKES!)
The KK is light duty - it has the 40 hp gearbox (vs the 60) and only weighs 525 lb (according to their web-site). I don't use the FEL - no stability problems (yet).
I only use it on flat, smooth ground -- to "clean up" the hay fields where the mower can't reach, around the grove, etc...
I wanted the 60 as it will, basically, cut to the width of the rear tires. If I can drive up close, I can cut up close.
If I had known the limitation, I probably would have not gone with that size. Maybe I would have opted for a sickle bar. But, I've had nothing to complain about, so far...
mlg
mlg
