I know EV’s try to use regenerative , over friction braking, as much as possible, but that persistent outer diameter surface rust pattern on the disc looks odd, considering you just drove it. Maybe the pads aren’t aligned flat with the disc yet? Maybe need to be bedded in more?
If you just put them up in your house, dirt cheap. Panels are super cheap on marketplace. I'm still working that out though.
The weird Triangle rims show too much brake disc too......I know EV’s try to use regenerative , over friction braking, as much as possible, but that persistent outer diameter surface rust pattern on the disc looks odd, considering you just drove it. Maybe the pads aren’t aligned flat with the disc yet? Maybe need to be bedded in more?
Yes, I think I'm going to turn regen braking off for a bit to better mate the pads and rotor.I know EV’s try to use regenerative , over friction braking, as much as possible, but that persistent outer diameter surface rust pattern on the disc looks odd, considering you just drove it. Maybe the pads aren’t aligned flat with the disc yet? Maybe need to be bedded in more?
Sometimes going down a grade with no traffic behind me I shift to N to disable Regen then apply the brakes to clear the surface.Yes, I think I'm going to turn regen braking off for a bit to better mate the pads and rotor.
Behind the wheel coversWhere are the lug nuts?
Thanks!Behind the wheel covers
His video of backing it off the trailer shows it without the covers on
