mostly likely broke it horseing around when i should not have been, basically using the fel like a dozer, digging up gums, privet, etc on land making food plots the last few months, at first you take it slow, but after awhile you try to push a little harder, and bad things happen, friday afternoon late getting dark, not sure if i had bucket at a bad angle, i saw fluid spraying so i backed out, took a few minutes to find the leak, had to be curling the bucket to get a spray
if i read correctly the warranty on the loader is 12 months, correct?
